Everything is a much more flexible search than Listary.
Integration with file open/close dialogs is only a few lines of AutoHotkey
and requires no complicated workarounds.
; Default shortcut is Win-A
$#a::
; Get the handle of the control that contains the current path
SendMessage, 1074, 17
; Get the current path
WinGetText, PathInTC, ahk_id %ErrorLevel%
; Cut off the trailing > and newline signs
StringTrimRight, PathInTC, PathInTC, 3
Send, {Raw}%PathInTC%\
Is Listary 6 Beta stable to try? I really want to have Search Result reorder by folder and I read that it is possible to do so in 6 Beta. But I don’t want to leave a stable 5 for a Beta 6. Sigh, I wish @Channing would get 6 out soon but I am not hopeful.
Ueli is very limited in what one can do with the results.
Keypirinha is much more flexibel
supports searches using Everything
offers a shell context menu for the results.
I have found Wox to be better than Ueli, particularly in its integration with Everything. On a computer where Listary doesn’t work, I use Wox and do a Copy Path on a found item to paste the folder location into file dialogs. (https://github.com/jjw24/Wox)
I also tested Wox now and I like it.
I have defined the Everything plugins Editor to my Total Commander
and can so jump directly to any files from the results using the context menu.
Wox has very good extensibility. However, I think KeyPirinha beats Wox in every category except for user-friendliness. It is a bit intimidating to set up, but the documentation is very good and after setting everything up, you’ll end up with your own personal launcher that offers a unique experience. Disappointed Listary developement has come to a halt, Listary 6 looked incredibly promising. Probably most upsetting is that it got left off at a point where it was 90% complete but the things left to be completed are very important. User-created extensions is the make or break here. I also can’t bring myself to use Listary 6 due to the lack of visual options, the default and only theme sticks out like a sore thumb on my desktop. If Listary was open-source I feel like we would be a lot farther down the line, seeing how much work has already been done.
In Keypirinha I must always select Everything search
before I can enter my search string.
In WOX I just enter the search string and it uses Everything for files and folders.
Also customizing WOX is much easier than editing Keypirinhas config files.
It is not a benefit for a tool in Windows to force the user to edit config files.
Hi guys,
Like you all I’ve been using Listary for years & been waiting for Listary 6. v5 works, but it’s buggy (crashes) and the options interface is horrible. I’ve gotten tired of waiting, so I will say goodbye to you all.
With that said I am trying out UELI + Wox + Keypirinha since all of them offer a portable version.
I hope Channing is OK and that the information posted here is false. Channing if you read this, thank you for everything. Best of luck to you all!
Hai guys, well as far my google translate can go…
Channing is fine and he is just busy.
Hopefully he can find some time to further develop listary 6
Gr, Leon
