@Channing Unfortunately I gave you an update too soon. Crashed twice since late yesterday afternoon.
Did the log files I provided, especially the last, provide any assistance?
Todd
Todd
That doesnāt work for me and here Ctrl+Enter does nothing
even after selecting an result by moving the cursor over it and its highlighted
So I have to use the context menu on any of the results.
Is there going to be a portable version of Version 6, and if so, wouldnāt be better to offer it during the beta so that people interested in testing it doesnāt install it until the stable one comes out.
The Quick Switch is working on Windows Explorer but I canāt make it work on XYplorer. Iāve added XYplorer to Integration under Options.
I did check all your log files:
Win + F2 hotkey combinations in the freeze log. Do you have any clue what could that be (especially the F2 part)? Could it be simulated by some other applications?Some extra questions:
There is no plan for a āstandardā portable version at the moment. The installer allows you to choose your own setting folder, which makes it really not very different from a portable version.
XYplorer support hasnāt been added yet. Itāll be available very soon. Please remove your own XYplorer integration setting as it will conflict with Listaryās built-in implementation.
The Hotkey was not set for this action, works now.
I use Total Commander as File manager.
request. Add a way to launch websites (in the default web browser) from Listary, in addition to the web search already available. Itās definitely faster than first opening a browser.
Please consider displaying longer path in folder history. I have the same named subfolders (i.e. c:\workā¦\1-2019, or \nas\archive\customer name\1-2019\ etc.) in different parent folders on different drives and now I cannot distinguish them in the menu.
Maybe displaying few first characters and last subfolder from the path would help.
In the file dialog listary behaves differently. when i start typing it does not get the focus, cant switch between the search results using the arrow keys. And I canāt reach the context menu either like āopen file locationā. In this case listary 5 was more handy for me.
Do you mean opening websites by typing/pasting URLs in Listaryās search box?
No worries. Listary will show long paths in an extra panel like what itās doing now in Explorer.
Thank you for your feedback. This will be fixed soon.
Yes
To address your questions:
As a workaround. You can add keywords for a website and use chrome to open it.
Listary 6 until now is very slow on poping up the search window (Ctrl-Ctrl), in one of my systems that have mechanical disks. Is it possible to make it more responsive?
Add support for Alt+Enter to open the Properties window, like in Windows File Explorer
