Listary 6 Beta šŸŽ‰
Hi Prowhiz,
I couldn’t get either of things to work. Is there a trick. Is there a setting?
With the dialogue open, press Alt+Space to call up the search and input the name of the folder or file you want and the dialogue will automatically switch to that directory. You can also click on the folder if it is open and when you click back in the save as dialogue, it will also update to the most recent folder
I also want to know. How do you do it? I follow your instructions but it doesn’t work, can you give more details?
Here’s a video demonstration you can watch. See if it works for you https://www.loom.com/share/8513f342a0854012925213e0eff9274b
You may need to turn on a setting to allow the file dialog update to the last visited folder in the file explorer. You can see that in this video: https://www.loom.com/share/633e9724299e4a7b817b8ea33fb4d168
hi prowhiz^^
u did great video, you should share on discord ^^
Yeah Thats a good idea
Yes, this are good features. but i still miss ctrl+G … because it’s just one keystroke.
and i don’t not always know the name of the folder where i want to go …
I’ve tried several alternatives but none had what Listary 6 has: choose a context menu item on a file with ease. Have I missed something? Does any one else use such workflow on any other alternative to Listary?
Demo: here I want to choose a context menu item ā€œGitExt Open Repositoryā€ on a file I know. This is bloody awesome and time saver for me in many scenarios. https://www.loom.com/share/048d472ad97747788ca91dda484d58d4
p.s. this demo is keyboard only (crucial for minimizing input switching)
Unfortunately the context menu presented by Wox is a sad shadow of actual context menu you’d get in File Explorer with very few items
This is not a good thing for search functionality. Have you used anything search-related from Microsoft? Bing? Windows 10 start menu search? File explorer search? They’re all shocking!
Windows 10 search for installed ā€˜TightVNC Viewer’ app. Search VNC, nothing??? Search Viewer, second result.
Google vs Bing. Google top result has the answer. Bing doesn’t have the answer in ANY of its results, and the top result is laughable.
Also, I’ve installed Fluent Search, and the search algorithm is simply not as good as Listary’s :frowning: I searched the same thing in both, and found the thing I was looking for in Listary and it wasn’t even in the list in Fluent… maybe I just need to learn more of the search syntax for Fluent, but in that case it’s not as intuitive as Listary. It’s also far slower. Search results take a few seconds to show, whereas Listary it’s half a second.
I also found Fluent to be worse than Listary and had to switch back, but at least it’s under active development so I’ll be keeping an eye on its progress. Seems like the most promising alternative to me.
Definitely the most promising, but they need a non-Microsoft employee working on the search algorithm… God their search tools are bad
u cant say that LOL
the dev of FS is working on azure, not on search tools LOL
by the way, yes listary is faster and sometimes more reliable, but u have to configure well Fluent search to be optimal.
it can do much more than listary, its a really good tools;
listary is version 5 or 6 in beta…
FS is even not on version 1.0…lol, since we used for few month, we already had dozen of dozen of update…
just need time to be as smooth as listary :slight_smile:
at least the dev is replying and active…not like listary.
If many here follow and trust Adir (FS dev) its because is active and open to any suggestion :slight_smile:
see u :slight_smile:
I know I can’t say that. Applications are only as good as the employees, and not all employees are equal. But it’s always good to have a dig at how bad Windows search tools are…
I’m sure Fluent Search might one day become a replacement for Listary, but while it’s not there yet, i’ll definitely be sticking to Listary, even if it’s EOL.
Set Fast Search to use all resources, it’s much faster.
It’s not that much slower then Listary. I still like listary better but Fast Search is getting there.
Too bad no sign of any works on final product.
Hope it’s not end of life.
It still works(beta 6) though.
It seems ā€œfolderā€ function is gone in beta 6, please bring this back…
folder:your_search
works fine in beta 6.
Also there will be no more changes to Listary.
Had the same performance issue with Fluent Search, contacted dev and now it’s really fast! Try latest nightly 0.9.89.40. There are still bugs here and there, but for me, performance is not an issue anymore
I set the folder search to ā€œf:ā€. Find it very useful.
regex does not seem to work properly
