My entire system froze suddenly 10 minutes ago. When I force-rebooted the system, Listary has since refused to start with this error:
Application: Listary.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.InvalidOperationException
at .()
at .()
at Listary.Core.ListaryApp.Start(System.String ByRef)
at Listary.Main.App.OnStartup(System.Windows.StartupEventArgs)
at System.Windows.Application.<.ctor>b__1_0(System.Object)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at MS.Internal.CulturePreservingExecutionContext.Run(MS.Internal.CulturePreservingExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
at System.Windows.Application.RunDispatcher(System.Object)
at System.Windows.Application.RunInternal(System.Windows.Window)
at Listary.Main.App.Main()
I tried launching Listary manually, but the same error appeared. Event Viewer shows Listary triggering a second error at C:\WINDOWS\System32\KERNELBASE.dll , too:
Faulting application name: Listary.exe, version: 6.0.5.16, time stamp: 0x5cd6d83d
Faulting module name: KERNELBASE.dll, version: 10.0.18362.476, time stamp: 0x83c3d83a
Exception code: 0xe0434352
Fault offset: 0x000000000003a839
Faulting process id: 0x4384
Faulting application start time: 0x01d5a49a7beadd49
Faulting application path: C:\Program Files\Listary\Listary.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: c65b2825-8b0b-429c-9664-9eea84d3e4e4
Faulting package full name:
Faulting package-relative application ID:
Then, within moments after restarting, Bitdefender threw this virus protection message:
I’m ready to uninstall & reinstall Listary 6, but 1) are there any more logs you’d need that could get deleted? and, 2) any reason why this happened and/or do we need to set an exception for Listary now in anti-virus programs?
Environment
Windows 10 Pro x64 1909 (18363.476)
Listary 6.0.5.16
Default Windows Explorer: no mods, no tweaks, etc.
