The beta is mostly working well for me, but thereās a new annoying behaviour in save file dialogs, where the filename in the dialog is changed to whatever file is selected in Listary as I type/hover over the list. I lose the original filename and when I go save, it asks me to overwrite the file with the same name, which frustrates me.
Sounds like a helper process ListaryHookHost64.exe crashed, but Iām not sure about the reason.
@Abdelrahman_Ehsouna @StylusEcho
Thanks for reporting. Iāll fix them.
Sorry but I donāt find these 3 icons on the right (star, clock, tools)
My bar shows only the search icon which is on the right (instead of these icons)
instead of being on the left as I see in this image.
Do I need to configure something?
Thanks
These 3 icons are only available on open/save file dialogs. The main search bar activated by Ctrl-Ctrl is designed for keyboard use, so it doesnāt contain menus.
The beta looks good so far, but I am noticing repeated issues with the accuracy of the returned results. Is this something that is still being worked on and will be addressed in furture versions?
thanks for all the hard work!
Looking forward to it because Iāve been missing this very much in v.6.
There is one problem Iād like to report: I canāt evoke the middle mouse button popup menu in the Open/Save file dialogs of Office 2003 ![]()
This is a deal-braker for me because I use Word 2003 all day long (and plan to do so also in the future). The menu is working without any problems in Listary v.5.
Thanks for looking into this!
Looks like its running:
Iām seeing odd behavior with the Action menu.
I have the Tab key set as the hotkey to bring up the action menu on a search result and sometimes that key takes me to an Actions list that just sits and spins with no actions to select. In those cases if I hit ESC and then Right Arrow (ā) I get the Actions list I expect to see. Other times the Tab key brings up the Actions list immediately.
Using the stock Windows Explorer on Win10. Doesnāt seem to be any pattern I can see, but will watch out for one more closely.
Any other reports of this?
Does it still happen if you choose a hotkey other than Tab? Note that Tab is used by Listary for auto-completion by default and this could be the cause.
Hi, can you upload some screenshots of the search result list showing inaccurate results?
Unfortunately Office 2003 is too old for Listary 6 to support
Iāll check if itās possible to bring it back after the beta becomes stable.
Interesting. Iāll look into this.
Is network support already implemented? Itās listed in the file search dialog, but it didnāt work.
EDIT: oh and I miss the integration of the Total Commander favourites menu, is that supposed to come?
You can already search mapped network drives. Open Options - Features - File Search - Index, and select āAdd a network driveā¦ā.
TC dir menu may be added later.
Hi @Channing.
Hereās an example. I am trying to reach the folder d:\apps\vscode
As you can see, with all the combinations of search terms, listary doesnāt find that folder (it doesnāt appear in any of the search results, even at the bottom, so itās not a question of result priority).
This has also happened to me with other folders and also files, but this is the most obvious example.
When using Listary in the Save As dialogue I cannot press the right arrow to select "Open Containing Folder). Pretty sure this worked in the previous version and would like to see this returning.
Oh wait, network drives are only supported as mapped drives?
They used to work as network path in v5
Extensions can return "type": "OpenUrl" to tell Listary to open a website when the search result is selected. What are the other possible ātypeā values?
Iām trying to use āstringsā to extract them but coming up empty. Iām writing a simple extension wrapper with TypeScript support that should make it easier to write and debug JS extensions.
EDIT: it appears that OpenUrl can also be used to open explorer windows and launch programs via āfile://ā However, I still donāt know how to launch a process and pass it command-line arguments.
@eddablin thank you for mentioning this. This is extremely useful for me also since I often remember a fileās name, but not the folder where it is.
