Issues with opening favorite folder
Hi, having a following issue Listary v5.00.2843
  1. Open Chrome
  2. Right click > “Save as”
  3. Middle/double click into the Save as dialog
  4. Click one of the Favorited folder
    Expected Result: The dialog will transition to the picked folder
    Actual Result: Dialog stays in the same folder. Another window gets moved above it focus switches to it
    AR(after Listary restart): Dialog stays in the same folder, nothing else happens
    AR(after PC restart): Dialog stays in the same folder. Another window gets moved above it focus switches to it
The Favorited paths exists, Listary even shows subfolders when hovering above the [>]
Any ideas how to fix this?
  1. Make sure you’re not running Listary as admin.
  2. Check if Listary 6 beta works: Listary 6 Beta 🎉
The current user is a member of administrator group but this behavior happens when the Listary process it Not elevated as well. This is a commercial usage with appropriate licence, can the same licence key be used for the beta app (and still be valid if I downgraded) or is Beta free to use in such case?
The beta version is free to use in a commercial environment.
