Dragging Listary UI SLOW
Steps to Reproduce
In 6.2.0.42, drag the popup launcher box around the screen.
Expected Result
Move the UI quickly, at the speed of mouse movement
Actual Result
As soon as I click down and begin moving, movement slows to a crawl and then occasionally speeds up/snaps to some location in the direction of movement
Windows Version
Edition Windows 10 Pro
Version 22H2
OS build 19045.4894
Experience Windows Feature Experience Pack 1000.19060.1000.0
Listary Version
6.2.0.42
Additional Information
No such problems here.
Did you try with the actual 6.3.1.81 ?
Windows 11 Home x64 Version 23H2 (OS Build 22631.4249)
Listary Pro 6.3.1.81
The “actual”? Is there a newer version? ‘Check for updates’ says 6.2.0.42 is the latest.
Look into this thread
https://discussion.listary.com/t/v6-3-1-81-beta-released-major-custom-index-and-stability-enhancements/9405
It also contains a download link.
Thanks! The dragging issue I described is gone in the beta version you linked (6.3.1.81)
