I’m brand new to Listary and purchased Pro today. My installation of Listary does not seem able to launch applications from their .LNKs.
For example, Ctrl-Ctrl -> Listary Opens -> Type in Notepad -> First result goes to the Programs/Accessories/Notepad.lnk -> Hit Enter -> Listary Closes -> Notepad does not open.
However if I search explicitly for notepad.EXE then it opens fine. This is consistent across all .lnk’s as far as I can tell.
I don’t know if this is user error or something else, any help appreciated.
Running:
Windows 10 Pro x64 Fall Creator’s Update
Listary Pro 5.00.2843
Thank you
