Steps to Reproduce
- Run Listary (default settings, in particular Integration > XYplorer is active with “Mouse middle-click to show popup menu”
- Open XYplorer (default settings)
- Open a few tabs (Ctrl+T)
- Middle click on a tab
- The tab is closed as usual, but also…
Expected Result
Nothing else should happen since middle click input was already handled to close the tab.
Actual Result
The contextual menu that appears when middle clicking in other places also appears which is a bit weird.
Windows Version
Windows 11
Listary Version
Listary v6.3.2.88
Additional Information
I disabled “Mouse middle-click to show popup menu” completely as I didn’t need it but some users may want it in general.
I understand that it may be difficult to tell whether XYplorer already processed that input. In this case maybe letting user customize popup menu custom to something else (e.g. Ctrl+Middle click) would help.
I tried to repro with native Windows 11 File Explorer to compare but the middle click didn’t open any contextual menu at all, so I can’t tell if there is the same issue…
