No problem here under Windows 11 with Listary 6.0.5.16
Windows 11 Home x64 Version 21H2 (OS Build 22000.282)
You sure? Its been crashing for me for ever, works 1 or 2 times then always crashes/stops. Every single time. I believe that was also the case with win10. this app is beta and hardly worked on
No problem as I said.
Its a beta and there will never be an update.
Its a dead product but the beta runs fine for me.
不仅仅是win11,我的win10今天发现Listary无法打开文件或者网页,所有文件和网页前面都有个感叹号
我找到可能的bug问题点了,如果是win官方打开窗口,是没有问题的,就是在使用wps的打开窗口会出现这个问题,请官方查看一下
I found the possible bug problem point, if it is win official open window, there is no problem, is the use of WPS open window will appear this problem, please official view
请问您是否使用的 V6.2.0.41 版本?这个版本的 autoupdater 有问题,需要麻烦手动升级至 V6.2.0.42 版本
