Why Won't Favorite Documents Open?
I’ve added documents under Options in the Menu section, but they won’t open. I made sure I was trying to open them in the correct application, and the two applications I want to use are listed in the By Application option.
While trying to figure out my problem, I also found that the config.xml file hasn’t been updated to the current date. Is this a bug?
  1. What are the application names?
  2. What is your Windows version?
config.xml is no longer used. This is normal.
  1. Applications are Jarte (for .rtf files) and Lotus WordPro (for .lwp files).
  2. Windows Vista Home Premium
