Everytime I used ctrl+ctrl to invoke Listary then input sc, it immediately triggered a WSL process??? Quite weird.
Currently I’m using 6.3.2.88.
Hi, Listary doesn’t actively execute any commands when you type sc — it only runs something after you press Enter. From your screenshot, it looks like the system is triggering WSL in the background.
This might be because you previously installed WSL, and even after uninstalling, some system settings may have been left behind — such as PATH configurations or default app associations. The system could still be associating certain keywords (like sc) with WSL, which is why you’re seeing the install prompt.
We suggest checking your system settings to see if anything is still linked to WSL — for example, wsl.exe in your PATH or any default open methods. These could be causing the issue.
Everything looks normal on our side, and Listary does not call WSL on its own. If you find any more clues, feel free to let us know.
