Hi, is there a way to not convert “/” character to %2F when using the search engine?
In the URL field in my web search, if I have something like: https://abc.com/{query}
If I type “example/one” as a {query},
the search will be https://gitlab.com/example%2Fone
instead of https://gitlab.com/example/one
The “web search” feature is designed specifically for searches, so we’ve added special handling to ensure the “/” character doesn’t become part of the path.
However, you can create a custom command to handle a “raw query” where “/” won’t be converted. Here’s an example in the screenshot below to help you set it up.
Unfortunately, that won’t be possible because these two requirements conflict with each other. If you’re using the suggestion provider, it assumes you’re entering a search query, not opening a path. If you’re opening a path, there’s no need for the suggestion provider.
