When using the context menu in Listary for Visual Studio Code. Visual Studio Code gets executed with Administrator rights. Which is annoying because the settings / plugins from the normal accounts are missing (and the security aspect of it).
When using normal Windows Explorer -> right Click -> Open with Code -> this doesn’t happen. Listary itself doesn’t not run in Administrator Mode. Atleast it’s not marked.
Llister running with nomal priviledges and under a normal user account
will never start any applications with enhanced rights.
You may have application shortcuts with the flag set to run as administraor
or you don’t run with a normal user account, which you should of course…
Also a normal configured system will create an UAC warning before running with enhanced rights.
