Typing bug
V8.3.2.88
I have been experiencing typing errors when I start typing from the desktop. It seems the second character typed is delayed and is inserted in the third- or fourth-character place.
This does not happen when I use the ctrl ctrl prompt or if I slowly type the characters.
It is quite frustration to have to retype search words.
Additional Information
No such effect or delays here.
Maybe you have some Autohotkey or similar scripts running in the background.
Windows 11 Home Version 24H2 (OS Build 26100.3915)
Listary Pro 6.3.2.88
Hi, thanks for the feedback!
We haven’t been able to reproduce this issue on our side. As Horst mentioned, it may be related to Autohotkey or similar scripts running in the background.
We recommend using Ctrl + Ctrl to launch Listary for now.
Same problem here, i have been complaining for at least 1 year
Hi @MasterTech and @riteshpgi — thanks again for reporting this!
We haven’t been able to reproduce the issue on our side so far, so we’d love to collect a bit more info to help narrow it down:
  • Are you using any custom input methods (like Japanese IME, Chinese Pinyin, or any third-party keyboard tools)?
  • Have you installed any desktop enhancement tools (such as animated wallpapers, floating widgets, or keyboard helpers)?
  • Any background tools like clipboard managers or scripting utilities running?
@riteshpgi — could you help describe the issue a bit more clearly when you get a chance?
Appreciate all the details — they really help us track things down!
I am using Windows 11 Pro, no keyboard tools or floating widgets. As you can see the listary freezes on typing and responds after considerable delay
Hi @riteshpgi ,
Thanks for the follow-up and the video.
We’ve noted down this bug. Appreciate your patience and detailed input!
Hi everyone,
For the typing delay bug, try fully uninstalling Listary and reinstalling the latest version.
Hopefully this helps!
