Hello. I have a suggestion/feature request: please add the option to make Listary semi-transparent and allow application below it to be activated when dragging the file from the search results. Now, when you need to drag and drop the file from the search results, very often, the program in which you want to drop said file is obstructed by Listary’s window. And moving Listary’s window, in this case, goes against Listary’s main function and objective - to streamline workflow and allow the user to manipulate the files in a blink of an eye ![]()
Thanks. This is a very reasonable suggestion. I’ll make Listary’s window hidden once you start dragging.
Thank you for the rapid response
