Total Commander Directory Menu in Listary (V7)
I’m currently still using Listary 5.x. In the “ToolBar” and “PopUp” menus, I use the option to display the Total Commander Directory Menu in Listary as well.
Are there plans to integrate this into Listary v7 as well?
I use it very often, like it and I miss it very much.
Many thanks
Andy
I made a global shortcut Ctrl-D using Quick Access PopUp
So I simply press Ctrl-D anywhere and the TC Directory Menu is displayed
Independent of TC is running or not.
Windows 11 Home Version 25H2 (OS Build 26200.8875)
Total Commander 11.58 x64 / x86
Listary Pro 7.0.0.5 beta
