In explorer and open/save-as dialog, listary is not searching in subfolders. It only shows files from current directory. I have Everything 1.2.1.371
In Directory Opus, standard Opus find-as-you-type toolbar at bottom appears, instead of Listary. If I use hotkey to bring Listary search and type part of a file name, it shows “no items match your search”.
I use default Listary 4 beta configuration, no changes were made.
Anyone have same issues?
This is really weird. I just tested it again on an absolutely clean Windows 7 machine and could not reproduce the bug. I’ll see if there are some other reports about the same issue.
I bought Listary Pro today from BitsDuJour. It is a great software. I am also trying Listary 4 beta right now but i have exactly same problem above.
I also tried to disable Opus built-in find-as-you-type feature but this time when i start to type something in DO lister, nothing happens.
@0xt1n
I’m sorry that you have to press the hotkey to bring up Listary in DOpus. This is a designed behavior of the current version.
About the “no items match your search”:
You need to have Everything installed and running.
FYI, here are some features that works perfectly with DOpus (using Listary 3.51):
1. After any open/save file dialog pops up, you can press Ctrl + G to jump to the folder you're viewing in DOpus directly.
2. If you switch from any file dialog to DOpus, do some work, jump to a new folder and then switch back to the file dialog, Listary will let the dialog open your working folder in DOpus automatically.
3. Press your mouse middle button or the hot key Win + W, Listary will show up with all your important and recent opened folders.
4. And many more...
Thank you for your useful tips. I also fixed “no items match your search” problem.
Unlike the Listary 3.51, i can not put the Listary Toolbar in a custom position by pixels in Listary 4 beta. Are you going to add this feature to Listary 4 also?
Again, I have the same issue. Listary worked fine just yesterday, and today, before I overwritten any files with new version) it stopped working.
In Explorer I hit Ctrl+W and Listary searches only in current directory and favorites. Search Everything results are not included. When I do the same in Directory Opus, only favorites are searched.
Today this beta works correct in both Explorer and Directory Opus. :doh:
This is what I do:
I normally use the latest stable version so I right click Listary tray icon, click Exit.
Run Listary.exe from the ListaryPortable folder.
3a. In Explorer - just type some name to search in subfolders.
3b. In Directory Opus - hit Win+S (my hotkey for show Listary toolbar) and type some name to search in subfolders.
And this is exactly what I did last time (when Listary searched only in favorites).
I have no idea what changed since last time I tried it. I didn’t reinstall Search Everything and didn’t change anything in Listary. (Oh, maybe except changing Win+W to Win+S :?
But even if that changed anything, when Listary didn’t work I renamed UserData folder to UserData_ to make Listary create new configuration files. Now - when Listary started working - I deleted current UserData folder and restored configuration saved in UserData_, ie. the old one that didn’t work. And Listary still works ok, so it must be something else than changing shortcut.)
