Sync between computers
Any way to sync preferences between 2 computers? I’m having no luck with symbolic links.
Copy
C:\Users\your_user_id\AppData\Roaming\Listary\UserProfile\Settings\Preferences.json
from one computer to the other while Listary is not running on the target.
I meant an actual ongoing sync rather than a one time copy. Like, ideally, I could just change the location of the user settings folder to be located on a dropbox folder, but that doesn’t seem to be an option. As I mentioned, I’ve tried symbolic links but that doesn’t seem to be working either (not sure why).
