I bought listary pro recently and quite satisfied. But file mgr I mainly use are not supported by listary, so I have to switch file explorer in windows between file mgr I use time to time.
Is there possibilities listary may supports file mgr other than total commander? The applicatios I use is Simple, easy and well designed softwares
