Dear community,
where are the settings of lystery stored, in which file.
I want to save the settings to use on another computer,and
also to save settings in case of volume crash.
Thanks
Peter
Try copying
C:\Users%username%\AppData\Roaming\Listary\Config.xml
This file does not seem to be created. I have a “Preferences” file, but not a Config.xml file.
Would be very good to have a way to import/export settings, especially index locations which can complicated definitions.
Version 6 stores its settings in
C:\Users\username\AppData\Roaming\Listary\UserProfile\Settings\Preferences.json
