In Total Commander Integration, when switched to tc, a new tab will be opened. I would rather open in the current tab; it may be a good idea to close the opened tab.
I think it should be configurable.
They will be configurable in future versions
i like that it opens it in new tab
how to use this Integration?
So far I can only open an explorer window from Listary.
And, since TC has its own quick search and it never shows a file dialog, why is TC listed in “By Window Type” of options of Listary?
Check this link: http://www.listary.com/total-commander-integration
Channing said:
@A117Check this link: Listary – Free File Search Tool & App Launcher
thank you very much.
Hi spg200, I made Total Commander as my default file manager in Listary.
You could find the details about how to setup this from this link:
http://www.listary.com/faq#How_to_set_Default_File_Manager_for_Total_Commander
and, if you delete the parameter /T
you will open file or fold in Total Commander in current tab.
Hope it helps.
