I used Listary 5, and I’m very happy that development is continuing with version 6.
I mainly use the popup menu, and I’m pleased that shell folders can now be defined using a CLSID.
The problem is that the contents of shell folders defined by CLSID are sorted inconsistently. For example, the contents of the Home shell folder are sorted in descending order with folders at the bottom. Other shell folders defined by CLSID are correctly sorted in ascending order but with folders and files mixed.
Folders defined by a regular path all seem to be sorted correctly.
It would be nice to have consistent sorting of folders or to have various sorting options.
Thanks
