Shortcuts for favorites menu folders
Please return back ability to set shortcuts for favorites menu folders including Desktop folder, as it was in Listary v5. It’s a really crucial feature. Thanks
Thank you for your suggestion. We will consider adding this feature in the future.
In the meantime, a less-than-ideal workaround is to add a ‘commands’ and specify the folder’s path in the ‘path’ section.
That was the reason I switched to Listary from other search engines. Please bring it back.
Thank you.
Same here, I switched to Listary from other search engines because of the menu folders added to the right of the search bar?
