Search exact text
Is it possible to search for files using exact text like " " in boolean search?
I’m using Listary Pro 6.
Any response here?
Following up again
If you enter a simple word, it shows all full matches first.
It is also having an And function.
For example, if I have a file named Documents-backup1.ect
To find it, I can enter
Documents backup
or
backup documents
But can I search exact text?
I.e. “documents backup” which will not return “backup documents”
No, currently not.
Listary is very limited in its search syntax.
I only using it for the support in Open / Save dialog.
For all real searching, I use Everything.
:expressionless: that affects?
How can I add “exact text” to the feature request list?
