Seach everywhere and listary 4 living together
Search Everywhere does not start automatically with windows as claimed; would be good if permission could be granted to incororate it
into listary’s installer and fix the auto start up problem. Also not sure what the most recent edition of seach everywhere is as have
not been able to successfully open the home web site.
Also listary’s About window lists listary as 4.00.1021 and is not being updated with each new new beta.
Sorry that I won’t change the behavior of Everything. This section from Everything faq may help:
1.12 How do I bypass the UAC to run "Everything" with administrative privileges on system startup? Disable run on system startup in "Everything". Follow the Make Vista launch UAC restricted programs at startup with Task Scheduler guide at http://blogs.techrepublic.com.com/window-on-windows/?p=616 Make sure you use -startup in the Add Arguments box
The version number will be fixed in the next version.
