After I press the right arrow key when I’m using the find as you type feature of Listary, I would like to be able to use the Mouse’s scroll wheel to navigate the context menu. Is that possible to implement in a future build, or is it already available and I’m just overlooking it?
The right arrow key menu does support mouse scroll wheel. Could you please give it another try?
You’re right. It works now. Thank you for your help. I have one more question, but I will make a new thread for it.
Still not working for me. I use Listary Pro under Windows 7 and 8 both 64 bits.
