Req. Add ability to add queries keywords AFTER search texts
Ex. I use “vid” as keyword to search videos. Often, I forget to type the keyword first, then the search texts (ex. Instead of “vid Samsung”, I would type “Samsung vid” to search for all videos with word Samsung). In that case, search result is empty. Make so the app applies the query whether it’s at beginning or end. Even worse, after I’ve already typed “Samsung” and, realizing my mistake, I press “Home key” to jump to beginning of sentence, then input vid + space, the search query won’t be applied. I have to delete the whole search and start anew.
Can’t confirm your problem with using the home key and typing the keyword.
You don’t need any space but the : which makes the complete keyword.
So press the home key add your keyword and a ":"
Windows 11 Home x64 Version 22H2 (OS Build 22621.1344)
Listary Pro 6.0.11.38
