I have tried to set up ` as my hotkey for listary, but it doesn’t works. I have to use key combination.
Definitely, one key is more faster than a key combination. So could please allow this function in the future version?
When listery can support system variables?
For example, if I want to run remote desktop connection, I typed ‘mstsc’ in listary but the result is not what I want.
So I have to register all exe files that I might use in command function.
I tried run >appwiz.cpl in lastary, but it doesnt work.
I have tried to set up ` as my hotkey for listary, but it doesn’t works. I have to use key combination. Definitely, one key is more faster than a key combination. So could please allow this function in the future version?
Sorry that Windows doesn’t allow to register a single key as hotkey.
When listery can support system variables? For example, if I want to run remote desktop connection, I typed ‘mstsc’ in listary but the result is not what I want. So I have to register all exe files that I might use in command function.
Try >mstsc
I’ll look into this one. P.S. The screenshot seems inaccessible.
Set at listary options a hotkey, for example Ctrl+Alt+Shift+F12
Then create an autohotkey script to include only
`::Send ^+!{F12}
Thats what I did, when Channing replied to me that the hotkey Alt+Space cannot be used as its native windows hotkey, but I was using launchy with the default hotkey Alt+Space and since replaced launchy with listary I wanted to keep the hotkey, so I added this line in my autohotkey script
!space::Send ^+!{F12}
Some application can support single key, for example, ditto. : )
So I dont know if that is possible to let listary support single key as hotkey in future version? We are counting on you Channing
Try
>mstscI tried run >appwiz.cpl in lastary, but it doesnt work.
The screenshot url is right, but I dont know why Markdown doesnt work in my post.
You can copy and paste it into url address to open it.
I know !() for image, but not work for me. ::sad
miked said:
Set at listary options a hotkey, for example Ctrl+Alt+Shift+F12Then create an autohotkey script to include only
`::Send ^+!{F12}
Yes, also a good solution. Thanks.
And I am always expect that listary can support single key as hostkey. I can wait : )
Just for reference
I run appwiz.cpl by this way.
create a command
input “rundll32.exe” in Path
input “shell32.dll,Control_RunDLL appwiz.cpl” in Parameter
It works.
Or
input “control” in Path
input “appwiz.cpl” in Parameter
also works and seems easier.
