I’m using Listary 5.00.2843 on Windows 10 64 bit V1903 build 18362.418
I’ve uninstalled and installed Listary more than once, but never does its recent option work.
The ‘Recent’ menu option always shows ‘Empty’.
Even though windows own ‘Recent’ menu does work correctly.
Pls help me resolve the same.
Unfortunately I’m still not able to reproduce this bug.
Do you mean History? I’m referring to Listary v6 by the way, which is simply THE utility program must have on Windows. Once you use it, you need it on all PCs you use or you end up crying! Ok maybe went too far there! History walks flawlessly for me by the way
I’m a long time user of Listary and know its corners.
My problem was that ‘Recent’ option wasn’t working in the said version of Listary (not the latest v6.x).
And I was telling that ‘History’ in windows is working fine, just in case it has something to do with that.
