Quick Switch Doesn't Work with Arm
Just moved to an ARM64 windows laptop. I am using Windows File Explorer and have just switched to “Files”. Neither seem to work with Quick Switch. I had it all working on my Intel machine - and it works for other people I know.
Also +1 for ARM native build as mentioned in Native build for Windows on ARM - English / General - Listary Discussions
“Files” is native ARM
Thanks for the feedback. Native build for Windows on ARM is in our plans. We will pay attention to this bug when we develop it.
Any update?
+1
Hoping to see the ARM version released before June 2025. I will go to powertoys in the meantime, but hope to come back to Listary as I love the software. I bought Listary 5, and would pay again for an ARM version.
Thanks for your interest.
ARM native support is in our plan, but it’s more complex due to low-level compatibility.
We’ll also look into the Quick Switch issue on ARM.
No exact timeline yet, but we’re working on it — thanks for your patience.
I use the script here which basically restores Quickscript for me. Should bring you back to Listary until they can implement.
JoyHak/QuickSwitch: Quickly Switch to the folder from any file manager.
I use the AHK script since a long time.
It’s better than Listary because it shows you the Paths from all tabs
of the supported file managers.
Listary only shows the active one.
Windows 11 Home Version 24H2 (OS Build 26100.3915)
Listary Pro 6.3.2.88
I quite like auto switch to active explorer window without a menu. I will be glad when its fixed in Listary because Listary was good with save as / open as dialogues where you could search for a folder and get to it from there.
it’s been a full year with no proper support. please finally release an update. this is the 5th time i downloaded the app and now have to delete it again. since:
  • drains battery since it is not native arm64.
  • the only feature i wanted it for doesn’t even work. quickswitch.
when released please @ me so I can redownload the app. and maybe consider subscribing to a paid plan if the support exists. Since right now it doesn’t…
Our whole business runs Listary and we have pro licences.
Adopting Arm laptops now and I think this will increase with the new snapdragon processors coming soon.
Have been trialling other softwares that do run in arm… But wish to remain with Listary.
Any update Listary? This coming 2026 hopefully?
Any update? Ctrl-g still doesn’t work with Arm.
native ARM64 build. working great on WOA.
