Hi and good day to all the comunity.
I just want to inform that Listary (in the dialog window for save/open a file) in Photoshop CS6 (i don’t know in other CS6 products)have an issue: Listary undergoes a continuous blinking, making it unusable in the dialog window.It’s really annoying.Hope you check out for yourself and fixed this.
PS:This did not happen with Photoshop CS5.
Hello raziel024,
I’m really sorry for the inconvenience. I’m downloading the trial version of Photoshop CS6 now and will look into this issue ASAP.
I have to confirm that. This blinking occurs in main CS6 apps: Indesign, Photoshop, Illustrator. Listary windows doesn’t work, only blinks.
Windows 7 x64.
Just adding my voice to the above. Same problem here, Windows 7 x 65 and the “blinking problem” occurs across the Adobe Creative Suite 6 programs. This problem did not occur in previous CS versions. (Using Listary Pro.)
Same here, CS6 applications on Windows 7 x64. Listary is functional via Folder Sync (sync folder dialog with explorer window), as I mostly use it anyway, also works on blank PS canvas via Listary shortcut (context menu), but blinks in all dialog windows.
I got same problem, but only in Illustrator and Indesign CS6, in Photoshop Listary works fine. I shoot short video - http://youtu.be/xuKFqI57TOQ. Windows 7 Ultimate x64.
This bug has already been fixed in Listary 4 beta.
I am using 4.01.1175 and the issue is still there
For me, using the beta 4 version worked fine with the Adobe programs. Now the current version 4 has the problem again, i.e. version 4.01.1175 (and the one before it).
It is fixed in 4.01.1180, so 4.01.1175 and versions before it still have the bug.
