Sometimes I want to delete few letters from Listary search field so I hold backspace for a while. If I hold for too long, it will result in closing Listary window and - what is worse - changing current folder I’m viewing.
I think it would be better if backspace didn’t close Listary window.
It seems to be more intuitive to just press backspace than ESC, then Win+S (you need to use more fingers to do so).
The only problem is when you press backspace one too many time or hold it too long.
I am using AutoHotkey to change this behavior of Listary. If anyone is interested, this the code I use:
#NoEnv
SendMode Input
SetTitleMatchMode RegEx
#IfWinActive ahk_class CabinetWClass ;Explorer
BackSpace:: ; Backspace pressed while Explorer Window active
; Change the non intuitive Listary Backspace behavior
; (going back in Explorer history instead of deleting last typed character)
; WinGet, listary_id, ID, ahk_class Listary_WidgetWin ; List and searchbox are two different windows. This proves to be the id handle of listary list window (we don't need that)
WinGet, listary_id_last, IDLast, ahk_class Listary_WidgetWin ; Get the id handle of listary searchbox window
if listary_id_last { ; Listary is active in the Explorer window
ControlGetText, listary_text, , ahk_id %listary_id_last% ; Get contents of the search field
; ToolTip, Listary is active: `nSearchBox id: "%listary_id_last%" `nSearchbox contained "%listary_text%" when key was pressed. ; You can uncomment this line for debugging purposes.
if (listary_text != "Search") { ; do not allow Backspace to exit Listary when the SearchBox is empty (contains "Search" - varies with language)
; but do send a Backspace key to the searchbox to delete the last typed character if it is not empty
ControlSend, ListarySearchBox1, {BackSpace}, ahk_id %listary_id_last%
} else { ; Listary not active in Explorer window, send the Backspace key to be handled by Explorer.
; ToolTip, Listary is not active
Send, {Backspace}
return
#IfWinActive ahk_class ahk_class Listary_WidgetWin ; Listary
BackSpace::
if (listary_text != "Search") { ; do not allow Backspace to exit Listary when the SearchBox contains "Search" , varies with language. Initially this field is blank, so you can exit with backspace if no letters at all have been typed yed.
Return
I registered just to backup this request. I can’t stress enough how many times I accidentally closed the search window while trying multiple short search query variations.
Please add at least an option (like a checkbox or something) to allow preventing backspace from closing the search window when it’s empty (cursor reaches the left boundary). I’ve been using Listary since it first came out, was probably among the first people to back it up by licensing the Pro version since it literally skyrocketed my productivity by enforcing keyboard-only approach. But this small usability issue is something that really drives me crazy from time to time. Please. Pretty please.
