xinyi
March 17, 2024, 2:13pm
Download link : https://www.listary.net/download/beta/Listary.exe
Follow Channing’s Twitter @ChanningDai to stay updated on the latest development status of Listary.
Listary V6.3 beta is out with another update! This time, we’ve fixed the memory leak in Listary-core and polished lots of small details. Give it a go!
V6.3.0.69 Changelog
Fixed: Resolved the memory leak issue within Listary-core.
New: Automatically searches all files by default, eliminating the need to manually enable “Rarely Used Files”.
Improved: Significantly enhanced the indexing mechanism for network drives and local folders.
Listary now automatically monitors changes, applicable to most NAS devices.
Prevents network indexes from rebuilding after startup.
Improved: Refined the user experience of the file search window.
Removed: The feature where double-clicking Ctrl closes the file search window.
Added: The Esc key can be used to clear the search query.
Improved: The “Rarely Used Files” toggle stays on by default.
Fixed: The issue where the file search window could not scroll horizontally.
Fixed: The issue where the search query overlapped with the cue banner.
Fixed: Some UI issues on the sidebar of the file search window.
New: Added an option to “Start Listary when Windows starts”.
New: Refined the priority UI to support easy restoration of default rules.
New: Introduced a Listary diagnostic tool for troubleshooting issues such as program freezes and high CPU usage.
Fixed: Crashes caused by attempting to open deleted, moved, or unauthorized files.
Improved: If a folder was previously opened, it will not open in a new window again.
V6.3.0.71 Changelog
V6.3.0.73 Changelog
New: Added a preview hotkey in the file search window for quick file previews.
New: Added OneCommander file manager support.
Improved: Significantly reduced the time it takes to open the launcher for the first time.
Improved: Listary no longer triggers when pressing a leading space in file dialogs, enhancing compatibility with utilities like QuickLook.
Fixed: Resolved a rare crash that occurred when processing Unicode characters.
Fixed: Addressed a potential crash that could happen when searching through history.
V6.3.0.75 Changelog:
New: Introduced support for Files (https://files.community/ ).
Fixed: Resolved an issue where Baidu search suggestions were not working.
Fixed: Addressed potential crashes in the disk search engine.
Fixed: Fixed a crash that occurred when opening files.
6.3.0.77 Changelog:
Fixed: Fixed some known issues.
horst
March 17, 2024, 5:31pm
Good improvements, but I still can’t restrict what drives to search for.
Example
D: some_search
It always finds all entries regardless of the drive.
This is very annoying if you have backup drives with the same files and dirs as C:
The Ignore list is no option as there are not only backup files on this drive.
YUccns
March 18, 2024, 12:15am
3
listary-core.exe Unable to ProcessPrng function to bcryptprimitives.dll
Windows 7 version 7601 Service Pack 1
xinyi
March 18, 2024, 12:35am
4
You can use D:\ some_search to restrict the drive.
xinyi
March 18, 2024, 12:49am
5
Sorry, starting from Listary V6, Windows 7 and XP are no longer supported. Some versions of Listary V6 might still run on Windows 7 and XP, but we cannot guarantee that every update will be compatible.
Joshua
March 20, 2024, 7:16am
7
Hi, since new update, Listary always throws an exception after few minutes:
xinyi
March 20, 2024, 7:55am
8
Could you please send the log files to support@listary.com ? Thanks.
Run ‘Listary.Diagnostics.exe’ as an administrator, located in the ‘C:\Program Files\Listary’ folder.
Click ‘Export Logs’ to export the log files.
I can confirm the issue too.
Maybe please also add download link for old versions in case current beta is crashing.
The only link I found is https://www.listary.net/download/beta/Listary.exe
I want to download the release just before the latest.
LISTARY 6.3.0.67 BETA.EXE 12.1 MB
Listary 6.2.0.42 Stable
https://www.listary.net/download/Listary.exe
The listary 5 is still snappier then listary 6. The listary 6.2.0.42 is stable but still slower than version 5. For me, all beta versions get slower with time. Then all of a sudden, listary stops functioning (doublt Ctrl does not work). If I try to right click listary in the taskbar, it gives a black window. Finally, I have to endtask and end listary.
I have gone back to the stable version…Lots of improvement required in listary 6…No doubt the functionality is better than version 5
xinyi
March 24, 2024, 12:30pm
12
This issue was fixed in V 6.3.0.71.
xinyi
March 24, 2024, 12:57pm
13
Could you specify which part is slow? Is it slow to start, slow in displaying search results, or something else?
You could try version 6.3.0.71, as a bug in version 69 might cause crashes.
The same issue still persists with 6.3.0.71
xinyi
March 25, 2024, 12:18pm
15
How can I help with the translation of Listary?
Thanks, for OneCommander file manager support.
xinyi
April 11, 2024, 5:30am
18
Thank you so much for your willingness to help! We handle our translations through Crowdin. You can find the project here: Listary dashboard in Crowdin
Ok. If I help with the translation, can I get a license for Listary Pro?
xinyi
April 14, 2024, 8:05am
20
Sure! Please send the request to support@listary.com . Thanks for the help.
