Open/Save Dialog and Click in Explorer window not working
I jsut noticed the when in a Save or Open dialog, the ability to click in an open Explorer window and then click back in the dialog and have the dialog change to the folder of the Explorer windows doesn’t seem to work anymore. I’m using Listary 6.0.9.25
I’m not sure what this feature is called, but it’s the closet I found to the Mac feature of dragging an item into the Save/Open dialog to switch the path to the item.
The Currently Open Folders in the context menu is OK, but it doesn’t seem to show open folder from mounts.
Any ideas?
That works fine here.
First it offers the current Explorer path
and after changing this in Explorer and go back to the dialog
it switches this to the new path.
Windows 11 Home x64 Version 21H2 (OS Build 22000.918)
Everything 1.5.0.1317a (x64)
Listary Pro 6.0.9.25
Whoops! I exited Listary and reopened it, and now it’s working.
