In both x64 and x32 editions of Windows 8 the search all drives >notepad.exe fails to find notepad.exe in windows\system32 or windows. Also everything search fails too. It does find some files, just not any ending in exe.
I find notepad.exe.mui .
Could you please upload a screenshot of the search results?
Also please make sure there is no Disk Search Exclude entries in Listary Options - Search.
I’m happy to oblige, but I’m experiencing difficultly capturing a screenshot as it’s not acting like an ordinary scrolling window. Also how do I upload it?
- Search >notepad.exe in Listary and leave the result popup window there.
- Press Print screen on your keyborad.
- open imgur and press Ctrl + V directory on that website.
- Paste one of the generated links here.
I’ve tried that and more. Pressing any hotkey and the list goes and it’s not captured. Anyway here is the result.
C:\Windows\WinSxS\x86_microsoft-windows-notepadwin_31bf3856ad364e35_6.2.9200.16384_none_3f74d8bfcc73d28a\notepad.exe
C:\Windows\Prefetch\NOTEPAD.EXE-2D2BD79A.pf
C:\Windows\WinSxS\x86_microsoft-windows-notepad.resources_31bf3856ad364e35_6.2.9200.16384_en-us_1a90e3f2a060e451\notepad.exes.mui
C:\Windows\WinSxS\x86_microsoft-windows-notepad.resources_31bf3856ad364e35_6.2.9200.16384_en-us_1a90e3f2a060e451\notepad.exe.mui
Sightly annoying is when I press the combination of WIN+s listary comes up with and “s” in the search box, so then I have to backspace it to remove it and then put in my search for character this quickly becomes irritating when I need to do this repeatedly.
Hmmm, is there really a notepad.exe in system32 or windows folder?
You do not need to press Win + S to bring up Listary. Just type what you need.
OK got a capture will upload.
Yes there is a notepad.exe in both system32 and windows.
Done the screenshots one of listary >notepad.exe and other of notepad.exe in system32. Please note there was no exclude folders. Also a similar problem occurs with (and I know it’s not your program but thought it interesting) everything search 1.3.1 and 1.2
Thanks for the screenshots. I’ll keep an eye on it.
