In the 3 below mentioned requests, I refer to “menus”. With this I mean the menu that is found in the Listary options under “Menus” with the red hart icon.
Could it be made possible to have different profiles for the menus.
Now you can only have one menu which contains your favourites, applications, commands…
But with profiles you could have different menu’s. Profiles switching could be done in different ways. I do not what the most effective way could be, but you could for example have set menuitem in menus which contains all the profiles?
Could it be made possible for folder links (.lnk) to resolve as actual folders in menus. For example I have a folder called “project a”
The menu has “project a” as an menu item, so when the user middle clicks mouse on desktop the menu pop’s up and when the user hovers over “project a” all the the folder links (.lnk) now also open op when hovering over them (just like normal folder). This would make it possible to have different locations in one folder.
Could it be made possible to have the option to “open” (fly-out) a folder item in the menu when you left click on it (in stead of automatically). If you actually want to open a menu item it could be done by double clicking on it. This makes navigating through the menu a bit more fluent because when you hover over a folder item which has many items (files/folders/…) in it, it stutters a little when trying to quickly move to another menu item. Maybe this also could render the menu even faster?
Thanks
