I would love to be able to double tap control, type 2+2, and when I hit enter the number 4 is put on my clipboard. Basically a simple math functionality. Maybe you need a precursor you can set much like folder:, but to be able to type in some quick math and hit enter and then be able to paste the result wherever I’m at would be awesome.
Hi Tom,
Are you using Listary 5? Try 6. The math function has been added.
Awesome, thanks!
So after using this feature a bit, it would be nice to be able to set a default rounding value. e.g. Always round to X numbers after the decimal. Don’t like ending up with like 7 digits.
I’ll consider making it more configurable.
