Looking for Some Best Practices for Using Listary to Boost Productivity?
Hi everyone,
I have been using Listary for a while now and I am amazed at how much faster it makes searching and accessing files. However…, I feel like I am only scratching the surface of what it can do. I would love to hear how you’re using Listary to improve your productivity !!
Some questions to get the ball rolling:
What are your favorite features, and how do you integrate them into your workflow: ??
Are there any advanced search tips or customization tricks you swear by: ??
How do you combine Listary with other tools like file managers, project management software, or automation scripts: ??
I am particularly interested in hearing about use cases for programming, creative work, or general productivity hacks.
Let’s share some ideas and help each other make the most out of this incredible tool !!
Looking forward to your insights.
Thanks !!
MarceloTableau
Well I’m answering to shake up this forum a bit where it seems that few people answer but I’m not sure I’ll come up with great answers compared to what you expect in terms of productivity.
What I advise you is what I use the most is to name your directories and files well to be able to find what you want very quickly and I use the control G function a lot to use all the power of a standard explorer with shortcuts, filters and Listary (I have several explorers open with the folders I’m working on and so I can quickly open the relevant explorer window) and then return to the software that interests me and click on control G to arrive at this directory.
Afterwards of course to gain in productivity you can also use filters but I’m not sure that in Listary programming can really help you, its purpose is to find files not to type things for you.
greetings,
