Windows 11, Listery 6.3.5.94
FYI my Listery settings to open found folders in XYplorer:
\Options \General \Open folder with:
Path: C:\Program Files\XYplorer\XYplorer.exe
Parameter: /reuse /path=“%1”
This doesn’t work with the actual x64 XYplorer.
Also, there is no switch /reuse according to the help.
For me, in dual pane mode the following parameters work
“%1”||“%1”
“/reuse” might be undocumented. Works for me to invoke from Eyerything search result folders in x64 XYplorer. But anyway, you are right: The “/reuse“ attribute today suddenly started Eyerthing and XYplorer from Listery.
I now use just “ /path=“%1” ”. And I will try your setting as well.
For Everything I have
“C:\Tools\XYplorer\XYplorer.exe” “%1”
But for Everything I prefer the script to get the GUI results
as XY paper folder.
