Hi, I just started using ver 6 of Listery and I have a question. How can I prevent Listary from displaying its popup menu when double-clicking on the desktop with the mouse?
Features / Hotkey
Disable Press Ctrl twice to show/hide Listary
But you loose the function for controlling file managers while in their screens.
Whats the problem with double-clicking on the desktop ?
Don’t do it or use ESC to close it.
