Listary with Start11 V2 (2.51)
I’m trying listary and i love it.
Noticed tho that it’s not putting its shortcut in the taskbar (only in the apptray in the bar).
I guess it’s due of me using Start11.
What is weird is that even if i disable Start11 enhancements the icon still doesn’t show up.
Any idea?
thanks!
This is the default behavior and has nothing to do with Start11.
You didn’t set up the taskbar to always show the Listary icon.
Listary is designed as an productivity tool, so if you close the Listary window, it will minimize to the system tray and disappear from the taskbar.
To make it stay visible in the taskbar, right-click the Listary icon in the taskbar and select “Pin to taskbar.” This way, it will always be displayed.
