Listary Preview Mode
When press Alt+Space it opens Listary
When you type text example Listary.png.
Then you press Alt+P for preview to see example off an picture.
Everythime you want to see an preview of the file everytime you need to press Alt+P.
My request is add an option in the options for toggle enable / disable button to keep the preview on or off.
Also I noticed when opening the preview window the window isn’t centered anymore, would be nice if the window also got more centered over the whole screen.
Kind Regards.
I just emailed them with the exact request, except, to have a feature where the image is already previewed in search.
I stumbled on flow launcher, it seems to have a worse and less intuitive experience,+ worse search. But this feature is a deal breaker for me, whenever i search for something, like “iphone” and I have an iphone picture, it will already show up in the search bar, so that I can choose between multiple ones I have. Same goes for video, it has a video preview, to know exactly which one it is.
Very useful
This is a working fix to enable always preview mode, without having to press Alt+P everythime you open it.
PhraseExpress:
Description Name: Listary: Preview Mode Always Enabled.
KeyPress: Alt+Space {{Command Open Listary, Can Be Different}}.
KeyPress: Z.
KeyPress: Alt+P.
KeyPress: BackSpace.
Place all the KeyPress on one Rule don’t use Enter, or Spaces.
Trigger HotKey: Alt+Space {{Command Open Listary, Can Be Different}}.
Output Target: Current Application.
Still the problem excist about the centered, can you please fix this Listary Team.
Hi, thank you for your suggestion!
Regarding the add an option in the options for toggle enable / disable button to keep the preview on or off., we’ll consider adding this feature in future versions.
In the meantime, you can use the image preview feature in the File Search Window, which can keep the preview always visible and might meet your current needs.
PhraseExpander Fix:
Abbrevation: Optional.
Short Cut: Alt+Space.
Script:
{#key ALT SPACE#}{#wait 100#}Z{#wait 100#}{#key ALT P#}{#wait 100#}{#key BACKSPACE#}
Fixes:
So at the moment there are two fixes you can fix it with PhraseExpress and also with PhraseExpander.
Ofcourse you can also wait if Listary going to add it in the settings.
