I have been using Listary for ages and have noticed that opening files with XYplorer via Listary no longer works.
I became the Error message: C:\Xyplorer%1 and nothing would found.
Can anybody help?
Please watch the video (gif).
Parameter: β{action_path}β
Hi, sorry for my late answer. But this makes no difference- anytime it opens a Search tab on XY with the %1 pattern.
These settings will work in Actions (Aktionen) Menu, if it works in General (Allgemein) I donβt know. Also you need to type: ββ for β{action_path}β
By the way C:\Xyplorer\Xyplorer.exe maybe you are using the wrong installed folder.
Thank you!
