After upgrading to 6.3 beta,Listary won’t work properly after every boots.I can’t use ctrl+g or any other hotkeys,and even no listary bar under file selectors.
If I try to open context menu of the tray or open the search bar,it will freeze there and explorer freezes then(also taskbar won’t responde to my most action).I must terminate Listary.exe and relaunch it to fix this.
It’s all good when using stable version 6.2.
I am also having a similar issue
