Listary hangs when using the context menu option to ‘Open File Location’ of a shortcut file.
This ‘Open File Location’ context menu is not a 3rd party add on; it is a standard built-in feature of Windows that is added to the context menu of all shortcut files.
When I search for a program name in Listary search bar, it searches the Start Menu and shows the .lnk shortcut file in the search results. But if I choose ‘Open Folder’ action, it opens the folder of the shortcut link, not the folder of the application.
Therefore, if I want to go to application folder, I have to select ‘open folder location’ from the context menu of the shortcut, and that it when Listary hangs (for 30 to 40 seconds). If I right-click a shortcut menu in Explorer and select ‘open folder location’, the application’s folder will open instantly (with no delay at all).
I tried to add “Go to Application” folder to the Actions menu, but Listary does not let you add a Command to the Actions menu.
