I tried various versions, including 4.2 and beta 1607. When I start listary, a prompt comes up and asks me if I want to submit a bug report (which I did, although I don’t like it). I also tried deleting the Listary folder under appData\Roaming, to no avail. Any ideas? Here is an example of a crash report, in case that helps:
<?xml version="1.0" encoding="UTF-8" ?>
<CrashRpt version="1402">
<CrashGUID>e23cf8eb-31cf-4c06-9f88-c802fefdaa32</CrashGUID>
<AppName>Listary</AppName>
<AppVersion>4.20.1553.0</AppVersion>
<ImageName>G:\incoming\Firefox Downloads\ListaryPortable\Listary.exe</ImageName>
<OperatingSystem>Windows 7 Enterprise Build 7601</OperatingSystem>
<OSIs64Bit>1</OSIs64Bit>
<GeoLocation>de-de</GeoLocation>
<SystemTimeUTC>2014-08-04T21:59:54Z</SystemTimeUTC>
<ExceptionAddress>0x75eec42d</ExceptionAddress>
<ExceptionModule>C:\Windows\SysWOW64\KERNELBASE.dll</ExceptionModule>
<ExceptionModuleBase>0x75ee0000</ExceptionModuleBase>
<ExceptionModuleVersion>6.1.7601.18409</ExceptionModuleVersion>
<ExceptionType>0</ExceptionType>
<ExceptionCode>0</ExceptionCode>
<GUIResourceCount>62</GUIResourceCount>
<OpenHandleCount>359</OpenHandleCount>
<MemoryUsageKbytes>19080</MemoryUsageKbytes>
<CustomProps />
<FileList>
<FileItem name="Preferences.json" description="" />
<FileItem name="crashdump.dmp" description="Crash Minidump" />
<FileItem name="crashrpt.xml" description="Crash Description XML" />
<FileItem name="portable.dat" description="" />
</FileList>
</CrashRpt>
