Hi @Channing. I am having several crashes, see screenshot.
Can you describe what you were doing with Listary when the crashes happened?
thanks for the prompt reply.
most of the times I am trying to open a file in some app (Ctr + O)
If you’re using 32-bit Windows, this is a known issue and will be fixed in the next version.
Hi, I am using 64 bit windows. I have this problem mainly when using xyplorer (32bit). i don’t know if that helps…
Thanks for the information. It seems that Listary crashes when the default folder of a file dialog is set to a specific folder on your system. The next time it crashes, can you take a screenshot of the full file dialog?
The dialog says your Windows was running out of memory. Check how much memory Listary uses and if Windows has some memory left.
