Listary Beta 4.01.1296
#####Download link
Installer
Portable version
#####Change log
  • New: The leading “>” is no longer needed to search all drives
  • New: New language files
  • Improved: Improve disk search preformance
  • Improved: Improve memory usage
  • Improved: Improve some Listary Options layouts
  • Fixed: Some bug fixes
Hi there. In previous version that I used (v4.01.1200), whenever I use the the keywords for projects, the top results are always folders. I really prefer that. In this new version, when I use Projects keywords, results are files and sometimes the folders don’t even show up especially in cases when there are multiple files bearing the name that I typed. I tried disabling fuzzy results to minimize the results that Listary show but nothing changed. This new version also shows files from different folders that has partial match to the word I typed eventhough I used the lead-in keyword for the Project folder. In my humble opinion, this version is not good, so for now I switched back to v4.01.1200.
@ajfudge
I’ll check this.
These results are shown in the Path section instead of the Project section. There should be nothing different from the previous version here.
Dear Channing,
There is no news since two months, when the new beta version is coming?
@0xt1n
Next week :slight_smile:
oh, that’s very nice!!
Hi, v4.01.1296 always crash at Windows startup. Sent report every times.
Could the new version fix this problem?
@iwong
It should have already been fixed now. Please wait for the next version to be released.
Dear Channing,
do you keep the option for search all drives with “>”?
because i have many cases for search local folder and sub-folders.
if listary has no swither for local/all drivers search, i will get too many un-useful items in abovt case.
@leeyaunlong
The option has been removed. Listary searches subfolders before searching other drives. And subfolder search results are always listed before other results (please make sure you’re using Listary’s disk search engine).
