Still no favourite, history links on the launcher?
Version 5 had it and it is the only reason I and many others used Listary but version 6 removed it.
Can you please re-introduce those back into version 6 please in the next update?
Thank you so much!
Having some problems running this version. Two PCs, both on Windows 10 x64 (10.0.19045) this error comes up when I double press ctrl, write anything in the listary “prompt” and press enter.
Everything worked fine in the last version.
Thanks in advance
totalcommander的快捷菜单自从6以后就没有了. 这个很难吗?搞不出来?
You mean the Total Commander Directory Hotlist.
This is not yet available in Listary version 6
Windows 11 Home x64 Version 23H2 (OS Build 22631.3810)
Everything 1.5.0.1383a (x64), Everything Toolbar 1.3.4
TC 11.03 x64 / x86
Listary Pro 6.3.0.78
